hi,
I am using a 4 core Intel(R) Xeon(R), 8gb ram with a vps.
I did panel installation smoothly.. but when I actived lscache and run CSS Minify (CSS Combine, JS Minify, CSS HTTP/2 Push can also be...) the server is being locked, cpu load reaches the %100 values.
Is there a setting this except for the default setting ?
Comments
Please try enable them one by one , to see which one is creating the load.
I did not look at the other. Is there a setting I missed?
if it doesn't , try disable all other plugins in your site and try CSS minify see if it overloads.
Problem can be around; htaccess permission, openlitespeed settings or php adjustment ?
All settings are default.
