Smtp Problem — CyberPanel - WebHosting Control Panel for OpenLiteSpeed
CyberHosting
Smtp Problem
hi i am having a problem can help you all the settings looks normal but tls can't activate
ErrorException: Email to em*****@gmail.com failed: [E_WARNING] stream_socket_enable_crypto(): Peer certificate CN=`host.cleared.com' did not match expected CN=`cleared'
Comments
  • Problem Solved
    /etc/dovecot/dovecot.conf
    Added
    auth_mechanisms = plain login
    Phpmailer
    Changed Server IP to Server Host Name
    $mail->Host = "hostname";
  • edited August 2019
    Warning: stream_socket_enable_crypto(): SSL operation failed with code 1. OpenSSL Error messages:
    error:14090086:SSL routines:ssl3_get_server_certificate:certificate verify failed in /home/XXXXXup.com/public_html/W3MAILBOX/YYYY/lib/class.smtp.php on line 368
    Fatal error: Uncaught phpmailerException: SMTP Error: Could not connect to SMTP host. in /home/XXXXXup.com/public_html/W3MAILBOX/YYYY/lib/class.phpmailer.php:1678
    Is anyone also facing the issue?
CyberPanel Discord
Howdy, Stranger!
