Centos 7 installation problem — CyberPanel - WebHosting Control Panel for OpenLiteSpeed
CyberLoader
Hello : I show for this error
"Unable to add CyberPanel official repository, exiting installer!"
Retrieving http://rpms.litespeedtech.com/centos/litespeed-repo-1.1-1.el7.noarch.rpm
D: ============== /var/tmp/rpm-tmp.lp8ktU
D: loading keyring from pubkeys in /var/lib/rpm/pubkeys/*.key
D: couldn't find any keys in /var/lib/rpm/pubkeys/*.key
D: loading keyring from rpmdb
D: opening db environment /var/lib/rpm cdb:0x401
D: opening db index /var/lib/rpm/Packages 0x400 mode=0x0
D: locked db index /var/lib/rpm/Packages
D: opening db index /var/lib/rpm/Name 0x400 mode=0x0
D: read h# 486 Header SHA1 digest: OK (489efff35e604042709daf46fb78611fe90a75aa)
D: added key gpg-pubkey-f4a80eb5-53a7ff4b to keyring
D: read h# 488 Header SHA1 digest: OK (95a91e98411949be93e80fa2833d7fe0350e0244)
D: added key gpg-pubkey-1bb943db-511147a9 to keyring
D: read h# 489 Header SHA1 digest: OK (28fb1bbb7741f90c6f2a0bf2e84f5e1ce3ebc780)
D: added key gpg-pubkey-83084d0e-4f57c17e to keyring
D: read h# 490 Header SHA1 digest: OK (fd829269ece9a3ef36df251a8aefe69752f351ac)
D: added key gpg-pubkey-cbc8b383-5576fc46 to keyring
D: read h# 491 Header SHA1 digest: OK (dd737a402556b7653c2bc971f343532046e26384)
D: added key gpg-pubkey-352c64e5-52ae6884 to keyring
D: Using legacy gpg-pubkey(s) from rpmdb
D: Expected size: 16824 = lead(96)+sigs(180)+pad(4)+data(16544)
D: Actual size: 16824
D: /var/tmp/rpm-tmp.lp8ktU: Header SHA1 digest: OK (6594109e4167c17d562f8ec103e89ccad44dca04)
D: added binary package [0]
D: ============== rpm
error: open of rpm failed: No such file or directory
D: ============== /var/tmp/rpm-tmp.5s8IA1
D: /var/tmp/rpm-tmp.5s8IA1: Header SHA1 digest: OK (6594109e4167c17d562f8ec103e89ccad44dca04)
D: Obsoletes: litespeed-repo = 1.1-1.el7.centos YES (added provide)
warning: package litespeed-repo-1.1-1.el7.centos.noarch was already added, skipping litespeed-repo-1.1-1.el7.centos.noarch
D: added binary package [1]
D: ============== /var/tmp/rpm-tmp.MeF3X9
D: /var/tmp/rpm-tmp.MeF3X9: Header SHA1 digest: OK (6594109e4167c17d562f8ec103e89ccad44dca04)
D: added binary package [2]
D: found 0 source and 3 binary packages
D: closed db index /var/lib/rpm/Name
D: closed db index /var/lib/rpm/Packages
D: closed db environment /var/lib/rpm
[03-41-32-Sun-Apr-2019] #########################################################################
[03-41-32-Sun-Apr-2019] Unable to add CyberPanel official repository, trying again, try number: 3
Comments
CyberPanel Discord
Howdy, Stranger!
In this Discussion
