I can't run SSL as Let's Encrypt by website list or SSL Menu > Manage SSL or command line. SSL issue looks like working when forced but as an matter of fact, not working for websites. All websites are down because of unsecure connection. What can i do?
Comments
If so I believe that is why verification is failing. But I didn't understand your point, SSL issued successfully from CyberPanel? what does the main log file says?
Latest logs:
[09-24-38-Mon-Jun-2019] Trying to obtain SSL for: XXX.XX and: www.XXX.XX
[09-24-42-Mon-Jun-2019] Failed to obtain SSL for: XXX.XX and: www.XXX.XX
[09-24-42-Mon-Jun-2019] Trying to obtain SSL for: XXX.XX
[09-24-51-Mon-Jun-2019] Successfully obtained SSL for: XXX.XX
[09-25-11-Mon-Jun-2019] No JSON object could be decoded
[09-27-02-Mon-Jun-2019] Trying to obtain SSL for: YYY.YY and: www.YYY.YY
[09-27-05-Mon-Jun-2019] Failed to obtain SSL for: YYY.YY and: www.YYY.YY
[09-27-05-Mon-Jun-2019] Trying to obtain SSL for: YYY.YY
[09-27-13-Mon-Jun-2019] Successfully obtained SSL for: YYY.YY
I think logs are not enough.
Cannot issue SSL. Error message: [Mon Jun 10 09:53:12 UTC 2019] Create new order error. Le_OrderFinalize not found. { "type": "urn:ietf:params:acme:error:rateLimited", "detail": "Error creating new order :: too many certificates already issued for exact set of domains: XXX.XX,www.XXX:XX: see https://letsencrypt.org/docs/rate-limits/", "status": 429 } [Mon Jun 10 09:53:12 UTC 2019] Please add '--debug' or '--log' to check more details. [Mon Jun 10 09:53:12 UTC 2019] See: https://github.com/Neilpang/acme.sh/wiki/How-to-debug-acme.sh [Mon Jun 10 09:53:14 UTC 2019] Create new order error. Le_OrderFinalize not found. { "type": "urn:ietf:params:acme:error:rateLimited", "detail": "Error creating new order :: too many certificates already issued for exact set of domains: XXX.XX: see https://letsencrypt.org/docs/rate-limits/", "status": 429 } [Mon Jun 10 09:53:14 UTC 2019] Please add '--debug' or '--log' to check more details. [Mon Jun 10 09:53:14 UTC 2019] See: https://github.com/Neilpang/acme.sh/wiki/How-to-debug-acme.sh 0,283 Failed to obtain SSL for domain. [issueSSLForDomain]
https://imgur.com/a/X0BdmVI
If I wait for 20 minutes and reboot server - everything works. The issue is present since 1.8.2 release. It is not critical, but very annoying.
Here are server logs:
2019-06-11 10:11:50.594191 [INFO] Rewrite directive: bypassed.
2019-06-11 10:11:50.594195 [INFO] Rewrite directive: bypassed.
2019-06-11 10:11:50.594199 [INFO] Rewrite directive: bypassed.
2019-06-11 10:11:50.594204 [ERROR] Invalid rewrite directive: php_value always_populate_raw_post_data -1
2019-06-11 10:11:50.594209 [INFO] Rewrite directive: bypassed.
2019-06-11 10:11:50.594213 [INFO] Rewrite directive: bypassed.
2019-06-11 10:11:50.594217 [INFO] Rewrite directive: bypassed.
2019-06-11 10:11:50.594222 [ERROR] Invalid rewrite directive: AddOutputFilterByType DEFLATE application/javascript
2019-06-11 10:11:50.594227 [ERROR] Invalid rewrite directive: AddOutputFilterByType DEFLATE application/rss+xml
2019-06-11 10:11:50.594232 [ERROR] Invalid rewrite directive: AddOutputFilterByType DEFLATE application/vnd.ms-fontobject
2019-06-11 10:11:50.594235 [ERROR] Invalid rewrite directive: AddOutputFilterByType DEFLATE application/x-font
2019-06-11 10:11:50.594239 [ERROR] Invalid rewrite directive: AddOutputFilterByType DEFLATE application/x-font-opentype
2019-06-11 10:11:50.594252 [ERROR] Invalid rewrite directive: AddOutputFilterByType DEFLATE application/x-font-otf
2019-06-11 10:11:50.594255 [ERROR] Invalid rewrite directive: AddOutputFilterByType DEFLATE application/x-font-truetype
2019-06-11 10:11:50.594259 [ERROR] Invalid rewrite directive: AddOutputFilterByType DEFLATE application/x-font-ttf
2019-06-11 10:11:50.594262 [ERROR] Invalid rewrite directive: AddOutputFilterByType DEFLATE application/x-javascript
2019-06-11 10:11:50.594266 [ERROR] Invalid rewrite directive: AddOutputFilterByType DEFLATE font/opentype
2019-06-11 10:11:50.594269 [ERROR] Invalid rewrite directive: AddOutputFilterByType DEFLATE font/otf
2019-06-11 10:11:50.594272 [ERROR] Invalid rewrite directive: AddOutputFilterByType DEFLATE font/ttf
2019-06-11 10:11:50.594275 [ERROR] Invalid rewrite directive: AddOutputFilterByType DEFLATE image/svg+xml
2019-06-11 10:11:50.594279 [ERROR] Invalid rewrite directive: AddOutputFilterByType DEFLATE image/x-icon
2019-06-11 10:11:50.594282 [ERROR] Invalid rewrite directive: AddOutputFilterByType DEFLATE text/css
2019-06-11 10:11:50.594285 [ERROR] Invalid rewrite directive: AddOutputFilterByType DEFLATE text/javascript
2019-06-11 10:11:50.594289 [INFO] Rewrite directive: bypassed.
2019-06-11 10:11:50.594293 [INFO] Rewrite directive: bypassed.
2019-06-11 10:11:50.594296 [ERROR] Invalid rewrite directive: BrowserMatch ^Mozilla/4 gzip-only-text/html
2019-06-11 10:11:50.594299 [ERROR] Invalid rewrite directive: BrowserMatch ^Mozilla/4\.0[678] no-gzip
2019-06-11 10:11:50.594303 [ERROR] Invalid rewrite directive: BrowserMatch \bMSIE !no-gzip !gzip-only-text/html
2019-06-11 10:11:50.594306 [ERROR] Invalid rewrite directive: Header append Vary User-Agent
2019-06-11 10:11:50.594309 [INFO] Rewrite directive: bypassed.
2019-06-11 10:11:50.594312 [INFO] Rewrite directive: bypassed.
2019-06-11 10:11:50.594315 [INFO] Rewrite directive: bypassed.
2019-06-11 10:11:50.594318 [INFO] Rewrite directive: bypassed.
2019-06-11 10:11:50.594323 [INFO] RewriteFile [/home/mautic.existance.co/public_html/.htaccess] parsed, return 0.
2019-06-11 10:11:50.594417 [INFO] [PlainConf] [virtualHostTemplate:] start parsing file /usr/local/lsws/conf/templates/ccl.conf
2019-06-11 10:11:50.606397 [INFO] [PlainConf] [virtualHostTemplate:] RCS checkin config file /usr/local/lsws/conf/templates/ccl.conf0 OK.
2019-06-11 10:11:50.606534 [INFO] [PlainConf] [context:/] rewrite [] add rules [rewritefile .htaccess]
2019-06-11 10:11:50.606585 [INFO] [PlainConf] [virtualHostTemplate:] start parsing file /usr/local/lsws/conf/templates/phpsuexec.conf
2019-06-11 10:11:50.618171 [INFO] [PlainConf] [virtualHostTemplate:] RCS checkin config file /usr/local/lsws/conf/templates/phpsuexec.conf0 OK.
2019-06-11 10:11:50.618302 [INFO] [PlainConf] [context:/] rewrite [] add rules [rewritefile .htaccess]
2019-06-11 10:11:50.618377 [INFO] [PlainConf] [virtualHostTemplate:] start parsing file /usr/local/lsws/conf/templates/rails.conf
2019-06-11 10:11:50.629518 [INFO] [PlainConf] [virtualHostTemplate:] RCS checkin config file /usr/local/lsws/conf/templates/rails.conf0 OK.
2019-06-11 10:11:50.629649 [INFO] [PlainConf] [context:/] rewrite [] add rules [rewritefile .htaccess]
2019-06-11 10:11:50.629696 [NOTICE] [ZConfManager] No VHosts added, do not send!
2019-06-11 10:11:50.630175 [NOTICE] [AutoRestarter] new child process with pid=12914 is forked!
2019-06-11 10:11:50.630914 [NOTICE] [child: 12914] Successfully change current user to nobody
2019-06-11 10:11:50.630958 [NOTICE] Child: 12914] Core dump is enabled.
2019-06-11 10:11:50.631031 [NOTICE] [Child: 12914] Setup swapping space...
2019-06-11 10:11:50.631140 [NOTICE] [Child: 12914] LiteSpeed/1.4.39 Open starts successfully!
2019-06-11 10:12:18.351445 [INFO] Tried to add new context: URI /serverlogs/ location /home/cyberpanel.existance.co/public_html//serverlogs/, result 0xf89ec0
[08-11-37-Tue-Jun-2019] Trying to obtain SSL for: existance.co and: www.existance.co
[08-11-43-Tue-Jun-2019] Successfully obtained SSL for: existance.co and: www.existance.co
[08-11-44-Tue-Jun-2019] Trying to obtain SSL for: existance.co and: www.existance.co
[08-11-50-Tue-Jun-2019] Successfully obtained SSL for: existance.co and: www.existance.co
seems SSL was success.
But the frontend drops an error.
systemctl restart lsws
Also are you accessing CyberPanel on port 8090 or did you follow this tutorial https://blog.cyberpanel.net/2018/12/25/how-to-remove-port-8090-from-cyberpanel/ ?
