Please help docker image volume mapping doesn't work — CyberPanel - WebHosting Control Panel for OpenLiteSpeed
Hello I want to install zammad helpdesk and in thier documentation they use docker compose . I have installed docker compose and successfully cloned the git repository. My question is in cyberpanel nextcloud docker tutorial it says to map volume with website path which we created inside cyberpanel like /home/example.com how do I specify this in docker compose yml ? This the file I need to edit and it has multiple volume for multiple containers do I need to change all the volumes to my website path? And how do I map port and reverse proxy ?? Where do I write the rewrite rules?? Please help I am stuck it's for my production server
https://github.com/zammad/zammad-docker-compose/blob/master/docker-compose.yml
Comments
Howdy, Stranger!
This Site is currently in maintenance mode.
Please check back here later.
→ Site Settings
