Power DNS Does Not Work. — CyberPanel - WebHosting Control Panel for OpenLiteSpeed
I'm using this code as the solution to the same problem I have;
pdns_server --config-dir = / etc / pdns /
but after a while the power dns shuts down again.
Comments
  • Hi
    i have same problem after upgrade just a momen ago
    here the output of status
    [[email protected] etc]# systemctl status pdns.service
    Active: activating (auto-restart) (Result: exit-code) since Jum 2019-10-04 01:12:34 UTC; 393ms ago
    Docs: man:pdns_server(1)
    man:pdns_control(1)
    https://doc.powerdns.com
    Process: 20524 ExecStart=/usr/sbin/pdns_server --guardian=no --daemon=no --disable-syslog --log-timestamp=no --write-pid=no (code=exited, status=218/CAPABILITIES)
    Main PID: 20524 (code=exited, status=218/CAPABILITIES)
    Okt 04 01:12:34 javanehslp.com systemd[1]: pdns.service: main process exited, code=exited, status=218/CAPABILITIES
    Okt 04 01:12:34 javanehslp.com systemd[1]: Failed to start PowerDNS Authoritative Server.
    Okt 04 01:12:34 javanehslp.com systemd[1]: Unit pdns.service entered failed state.
    Okt 04 01:12:34 javanehslp.com systemd[1]: pdns.service failed.
    here the permission file and folder
    [[email protected] etc]# ls -l |grep pdns
    drwxr-xr-x 2 pdns pdns 4096 Okt 4 00:53 pdns
    [[email protected] etc]# ls -l pdns
    total 36
    -rw------- 1 pdns pdns 15680 Jul 31 2018 pdns.conf
    -rw------- 1 pdns pdns 17232 Okt 3 14:13 pdns.conf.rpmnew
    i can not find the detail log.
  • Can you try using these permissions and then restart it?
    chown root:root /etc/pdns/pdns.conf
    chmod 644 /etc/pdns/pdns.conf
    See this thread for reference.
    https://forums.cyberpanel.net/discussion/1868/suddenly-power-dns-and-pureftpd-stopped#latest
  • Hello I made everything and powerdns still down ;(
    After updated to the last 1.9.1 version of cyberpanel and 1.5.6 version of OLS
    Any help please ? i have sites on production and a Facebook ads running ;(
    HELP
    Thanks
    Fabian
Howdy, Stranger!
This Site is currently in maintenance mode.
Please check back here later.
→ Site Settings
