CyberHosting
CSF setting required ///// urgent
I would like to block port 25/587/465/2525 ( SMTP ports ) from everywhere except my country ( India)?
NOTE - PORT 80 & 443 from everywhere.
I am looking for block access so that no one can access the server for spamming.
Comments
  • While it is possible to do this, your vps/server will crawl to a halt due to the sheer amount of cidr in each country, i will not be irresponsible and guide you further into this, try to a strike a deal with your upstream to make use of hardware firewall to do this since i assume you are a reseller.
  • Thanks @Numeriku.
    Any way/method which secure server 100% from spamming?
    1 ) PHP mail function disabled on the server
    2 ) SMTP_Block is enabled and only required users having SMTP access.
    What else required to protect mail server / postfix ?
  • make sure you have the postfix main.cf
    set to
    smtpd_sasl_auth_enable = yes
    smtpd_sasl_security_options = noanonymous
    /etc/postfix/main.cf
    As long as you are not using insecure scripts that people can access then you shouldnt have any issue with spammers sending mail through the server.
    Cyberpanel Managed & Unmanaged Shared & VPS Hosting by Cyberpanel Experts.
    https://www.cyberhosting.org
  • @hennaboy - Already having above setting on the server.
    Thanks.
CyberPanel Discord
Howdy, Stranger!
