I could not find the opening topic. I have the same problem. Everything was normal last night, but I can not get into FTP today. version : http://prntscr.com/kr0noj please help me. tired now: S thank you
Type your comment> @xpto said:
> In new installation I have the some problem I cant login through the FTP
> what I did was
> 1- I deleted the FTP Firewall entry
> 2- re-entered an entry for FTP again in Firewall.
> I tested the FTP entry and everything went well and it works .. :)
Can you tell me more about commands done in SSH ?!
Comments
Hello @jainsumit12
What path did you set while creating FTP account?
HI Hope.
/home/demo.adinathwebsolution.com
that is path address.
Server > Security > Firewall
Turn off firewall and give it a try.
yes, its working when turn of FireWall. but is there is any solution so we don't need to turnoff Firewall every time.
please send a bug report to [bug at litespeedtech dot com]
use iptables to open port 21 (ftp port)
iptables -A INPUT -p tcp -m tcp --dport 21 -m conntrack --ctstate ESTABLISHED,NEW -j ACCEPT -m comment --comment "Allow ftp connections on port 21"
iptables -A OUTPUT -p tcp -m tcp --dport 21 -m conntrack --ctstate NEW,ESTABLISHED -j ACCEPT -m comment --comment "Allow ftp connections on port 21"
Allow FTP port 20 for active connections incoming and outgoing
iptables -A INPUT -p tcp -m tcp --dport 20 -m conntrack --ctstate ESTABLISHED,RELATED -j ACCEPT -m comment --comment "Allow ftp connections on port 20"
iptables -A OUTPUT -p tcp -m tcp --dport 20 -m conntrack --ctstate ESTABLISHED -j ACCEPT -m comment --comment "Allow ftp connections on port 20"
Finally allow FTP passive inbound traffic
iptables -A INPUT -p tcp -m tcp --sport 1024: --dport 1024: -m conntrack --ctstate ESTABLISHED -j ACCEPT -m comment --comment "Allow passive inbound connections"
iptables -A OUTPUT -p tcp -m tcp --sport 1024: --dport 1024: -m conntrack --ctstate ESTABLISHED,RELATED -j ACCEPT -m comment --comment "Allow passive inbound connections"
Just tested on this end and i managed to open the Passive ports using the following:
firewall-cmd --add-service=ftp
google cloud ftp
Are you able to solve your issue?
Blog
Not only FTP port 20 ,21 default FTP TLS tcp port is 40110-40210
The installation opens these ports by default, are you having any issues?
Blog
I am using GCP firewall , disable CentOS's Firewall . Add a firewall rule accept
tcp:21
tcp:60000-61000
tcp:20
And then the ftp is worked .
Yup, you need to open ports on GCP firewall too.
Blog
Also, mention the version.
Blog
thank you
what I did was
> what I did was
