Cron jobs not working and not listed — CyberPanel - WebHosting Control Panel for OpenLiteSpeed
CyberLoader
Provider: Digital Ocean
Virtualization Type: KVM
System: Ubuntu 18.04
Installation option:
OLS or Enterprise?
OLS
official
no
yes
Install LiteSpeed Memcached?
yes
Install Memcached?
yes
yes
Install Redis?
yes
Problem:
I added a cron job on the CyberPanel. The job is created to /var/spool/cron/[username], but not appears on the Cyber Panel Cron Management list, and not running.
The command looks like this: php /home/[domain]/public_html/script.php
PHP file owned by user, chmod 777.
Please help! Thanks!
Comments
  • Info: The Cyber Panel is a fresh install, latest version 1.9.2.
  • Someone? Nobody knows the solution? :(
  • If I modify the cronPath on the cronUtil.py, the listing is works fine.
    def getWebsiteCron(externalApp):
    try:
    if ProcessUtilities.decideDistro() == ProcessUtilities.centos:
    cronPath = "/var/spool/cron/" + externalApp
    else:
    cronPath = "/var/spool/cron/crontabs/" + externalApp
    I removed crontabas/ in else branch.
    Now looks like this:
    try:
    else:
    However, cron tasks will not run.
    What's the real problem? What is not configured well?
  • On AddNewCron function is missing the operating system test on CronPath:
    def addNewCron(externalApp, finalCron):
    try:
    CronPath = '/var/spool/cron/%s' % (externalApp)
    with open(CronPath, "a") as file:
    file.write(finalCron + "\n")
  • This part seems to be quite problematic under Ubuntu.
CyberPanel Discord
Howdy, Stranger!
In this Discussion
