web not accessible after enabling firewall — CyberPanel - WebHosting Control Panel for OpenLiteSpeed
CyberHosting
hi
any one face such issue
firewall is blocking me to access website / control panel , even not able to add records ,, i Nees to stop with " systemctl stop firewalld" .
Comments
  • edited May 2018
    I do update cyperpanel but sill same issue ! any idea
  • here are the commands, add port manually to solve this issue
    # firewall-cmd --add-service=ftp
    # firewall-cmd --add-service=http
    # firewall-cmd --add-service=https
    # firewall-cmd --zone=public --add-port=8090/tcp
  • [09-04-40-Fri-May-2018] #########################################################################
    [09-04-40-Fri-May-2018] FirewallD successfully enabled on system startup!
    FirewallD is not running
  • edited May 2018
    what I guess is because of bug with ver 1.6.4 or need to run without yum update , the previous one was working fine
    There is something wrong with Centos 7.5, firewalld does not start. Or even in Centos 7.3 after yum update.
  • edited May 2018
    hi;
    I am sure somehow it is cyberpanel bugs,
    it is saving when adding a new rule , bt not updating old rules so you need add them manually.
    you have two choice -
    first stop firewall form ssh
    # systemctl stop firewalld
    1- delete rules one by one and add them manually
    [ OR ]
    2- replace attached public.xml file located in >> /etc/firewalld/zones
    # reboot
  • khamiss said:
    hi;
    [ OR ]
    # reboot
    You are testing firewalld on plain or CyberPanel server?
  • on CyberPanel server
  • I am having this situation. However, it depends on the VPS installed. Some VPS has such a firewall error, others don't
CyberPanel Discord
Howdy, Stranger!
