403
Forbidden
Access to this resource on the server is denied!
I am getting this error after using 1 click wordpress installation.
Plz check inmarking. Com for error.
I have the same problem ie '403 Forbidden' page after WordPress+LSCache install from CyberPanel 1.9.4.
Is there a solution yet, or should I just use PHP 7.3 instead of 7.4?
By the way, what is the simplest way to delete the failed PHP 7.4 WordPress install so that I can reinstall it again on PHP 7.3 (is it even necessary to do this)? Can I just delete the WordPress home directory from command line in Ubuntu using the command: deluser --remove-home my-wp-user
Comments
