HELP me: Email not receiveing after setting up filtering spam in rainLoop — CyberPanel - WebHosting Control Panel for OpenLiteSpeed
CyberLoader
I need urgent help with sieve
I setted up this carefully following all steps:
https://blog.cyberpanel.net/2019/04/18/filtering-spam-in-rainloop-autoreply-and-email-filters-with-sieve/
at the end of process: the fliters did not worked in individual accounts nor receiving emails in any ofthe server accounts.
I can send with no issues but i cannot received
The only difference Ihad with the settings was the first line:
Append “sieve” after ‘lmtp’ in protocols on the first line:
protocols = imap pop3 lmtp sieve
the difference was that i did not have lmtp on that line .
I have gone back correcting the settings to protocols = imap pop3 that is what I had at the beginning, ut still not working
I have centos 7
Comments
  • edited January 2020
    this also i did to enble lmpt
    edit /etc/dovecot/conf.d/20-lmtp.conf file to configure dovecot to enable the sieve plugin.
    protocol lmtp {
    # Space separated list of plugins to load (default is global mail_plugins).
    mail_plugins = $mail_plugins sieve
    do not know what has gone wrong as I followed instructions as they are
  • make sure hostname is set to your email server hostname in the dovecot.conf file: postmaster_address = [email protected]
    hostname = mail.mydomain.com
  • Also make sure that port 4190 is opened in your firewall
    this one not opened, how shall I do it?
  • [[email protected] ~]# netstat -tunlp | grep :4190
    tcp 0 0 0.0.0.0:4190 0.0.0.0:* LISTEN 16312/dovecot
    tcp6 0 0 :::4190 :::* LISTEN 16312/dovecot
    udp 0 0 0.0.0.0:41901 0.0.0.0:* 2238/openlitespeed
  • Thanks @NiiYankee
    gone through all again opened port 4190, hostname and postmaster changed to mine
    and firewall opened,
    21 sieve tcp 0.0.0.0/0 4190
    still no emails through
  • There is a bud in the sieve script. This is the error I got also: sieve: Failed to access user's personal storage (temporary failure)
  • how can I revert? I have some very angry clients
  • Type your comment> @solopedro said:
    > Thanks @NiiYankee
    Remove sieve and its configurations and your emails should start coming in again. Wait until there is a fix then try it again. After all, sieve with rainloop is beta.
    Follow these steps:
    1. sudo yum remove dovecot-pigeonhole -y
    2. nano /etc/dovecot/dovecot.conf and remove the following: lmtp sieve in the first line then remove this: service auth {
    unix_listener auth-client {
    group = postfix
    mode = 0660
    user = postfix
    unix_listener auth-master {
    group = vmail
    mode = 0660
    user = vmail
    user = root
    service managesieve-login {
    inet_listener sieve {
    port = 4190
    service managesieve {
    protocol sieve {
    managesieve_max_line_length = 65536
    managesieve_implementation_string = dovecot
    log_path = /var/log/dovecot-sieve-errors.log
    info_log_path = /var/log/dovecot-sieve.log
    plugin {
    sieve = ~/dovecot.sieve
    sieve_global_path = /etc/dovecot/sieve/default.sieve
    sieve_dir = ~/sieve
    sieve_global_dir = /etc/dovecot/sieve/global/
    lda_mailbox_autocreate = yes
    lda_mailbox_autosubscribe = yes
    protocol lda {
    mail_plugins = $mail_plugins autocreate sieve quota
    auth_socket_path = /var/run/dovecot/auth-master
    log_path = /var/log/dovecot-lda-errors.log
    info_log_path = /var/log/dovecot-lda.log
    protocol lmtp {
    log_path = /var/log/dovecot-lmtp-errors.log
    info_log_path = /var/log/dovecot-lmtp.log
    3. Save the dovecot.conf file
    4. Remove the folder at /etc/dovecot/sieve/global
    5. systemctl restart dovecot
    6. systemctl restart postfix
    Your emails should start rolling in again
  • Thanks a LOT @NiiYankee you are a star!!
    All coming through now
  • I found the solution for the sieve error on the forum: in the dovecot.conf file look for:
    plugin {
    sieve_dir = ~/sieve
    and replace with this:
    plugin {
    sieve = /home/vmail/%d/%n/dovecot.sieve
    sieve_dir = /home/vmail/%d/%n/sieve
  • Won’t risk I followed the instructions exactly as they appear and did not work. So until they are correct prefer spam. Even if with the set to delete (1) in server does not work either
    Usually, this happens when the Spamassassin line in /etc/postfix/master.cf is wrong. Seen this on some installations.
    If this is an existing installation then the below is how i setup that for all clients sieve to work by default to spam folder of Rainloop "INBOX.Junk E-mail".
    Install spamasassin via cyberpanel
    backup configs:
    cp /etc/dovecot/dovecot.conf /etc/dovecot/dovecot.conf-bak_$(date '+%Y-%m-%d_%H:%M:%S');
    cp /etc/postfix/master.cf /etc/postfix/master.cf-bak_$(date '+%Y-%m-%d_%H:%M:%S');
    cp /etc/postfix/main.cf /etc/postfix/main.cf-bak_$(date '+%Y-%m-%d_%H:%M:%S');
    cp /etc/dovecot/dovecot.conf /etc/dovecot/dovecot.conf-bak-sieve
    cp /etc/postfix/master.cf /etc/postfix/master.cf-bak-sieve
    cp /etc/postfix/main.cf /etc/postfix/main.cf-bak-sieve
    Please NOTE:
    TO reverse these modifications the below commands can be used.
    cp /etc/dovecot/dovecot.conf-bak /etc/dovecot/dovecot.conf
    cp /etc/postfix/master.cf-bak /etc/postfix/master.cf
    cp /etc/postfix/main.cf-bak /etc/postfix/main.cf
    service dovecot restart && service postfix restart;
    service dovecot status && service postfix status;
    Install required packages
    Ubuntu
    apt-get install -y dovecot-managesieved dovecot-sieve net-tools pflogsumm
    Centos
    yum install nano net-tools dovecot-pigeonhole postfix-perl-scripts -y
    Empty the current config
    copy in the new base one via nano. Replace "server.example.com" with your hostname and example.com with your domain name.
    protocols = imap pop3 sieve
    log_timestamp = "%Y-%m-%d %H:%M:%S "
    mail_location = maildir:/home/vmail/%d/%n/Maildir
    #mail_location = mdbox:/home/vmail/%d/%n/Mdbox
    ssl_cert = <cert.pem
    ssl_key = <key.pem
    mail_plugins = zlib
    mdbox_rotate_size = 2M
    namespace {
    type = private
    separator = .
    prefix = INBOX.
    inbox = yes
    service auth {
    mode = 0600
    user = vmail
    unix_listener /var/spool/postfix/private/auth {
    mode = 0666
    user = postfix
    group = postfix
    user = root
    service auth-worker {
    user = root
    protocol lda {
    log_path = /home/vmail/dovecot-deliver.log
    mail_plugins = zlib
    protocol pop3 {
    pop3_uidl_format = %08Xu%08Xv
    mail_plugins = $mail_plugins zlib
    protocol imap {
    mail_plugins = $mail_plugins zlib imap_zlib
    passdb {
    driver = sql
    args = /etc/dovecot/dovecot-sql.conf.ext
    userdb {
    driver = sql
    plugin {
    zlib_save = gz
    zlib_save_level = 6
    port = 4190
    protocol sieve {
    plugin {
    protocol lda {
    mail_plugins = $mail_plugins sieve quota
    hostname = server.example.com
    protocol lmtp {
    service stats {
    unix_listener stats-reader {
    user = vmail
    group = vmail
    mode = 0660
    unix_listener stats-writer {
    user = vmail
    group = vmail
    mode = 0660
    Create directories and permissions.
    mkdir -p /etc/dovecot/sieve/global
    touch /var/log/{dovecot-lda-errors.log,dovecot-lda.log}
    touch /var/log/{dovecot-sieve-errors.log,dovecot-sieve.log}
    touch /var/log/{dovecot-lmtp-errors.log,dovecot-lmtp.log}
    touch /etc/dovecot/sieve/default.sieve
    chown vmail: -R /etc/dovecot/sieve
    chown vmail:mail /var/log/dovecot-*
    nano /etc/dovecot/sieve/default.sieve
    require "fileinto";
    if header :contains "X-Spam-Flag" "YES" {
    fileinto "INBOX.Junk E-mail";
    Sieve the global spam filter
    sievec /etc/dovecot/sieve/default.sieve
    Restart and check services are up and then test.
    service dovecot restart && service postfix restart && service spamassassin restart;
    service dovecot status && service postfix status && service spamassassin status;
    Start tailing logs:
    tail -f /var/log/{maillog,mail.log,mail.err,syslog}
    Sent your test Junk email with the below in the body of the email:
    XJS*C4JDBQADN1.NSBN3*2IDNEN*GTUBE-STANDARD-ANTI-UBE-TEST-EMAIL*C.34X
    If you get the this message but are not seeing the email in the inbox and permissions and everything else is right:
    delivered via spamassassin service)
    Open config file and change the below line
    nano /etc/postfix/master.cf
    spamassassin unix - n n - - pipe flags=R user=spamd argv=/usr/bin/spamc -e /usr/sbin/sendmail -oi -f ${sender} ${recipient}
    To:
    spamassassin unix - n n - - pipe flags=DROhu user=vmail:vmail argv=/usr/bin/spamc -f -e /usr/libexec/dovecot/deliver -f ${sender} -d ${user}@${nexthop}
    If this is on Ubuntu the line might need to be using the Ubuntu lib path of /usr/lib/dovecot/deliver
    spamassassin unix - n n - - pipe flags=DROhu user=vmail:vmail argv=/usr/bin/spamc -f -e /usr/lib/dovecot/deliver -f ${sender} -d ${user}@${nexthop}
    Optional things that might be needed.
    If you get this error:
    spamc[7957]: connect to spamd on ::1 failed, retrying (#1 of 3): Connection refused
    Disable IPv6:
    Append below lines in /etc/sysctl.conf:
    nano /etc/sysctl.conf
    net.ipv6.conf.all.disable_ipv6 = 1
    net.ipv6.conf.default.disable_ipv6 = 1
    To make the settings affective, execute :
    sysctl -p
    Add missing spamd user:
    groupadd spamd
    useradd -g spamd -s /bin/false -d /var/log/spamassassin spamd
    chown spamd:spamd /var/log/spamassassin
    Create this file with the below value to ensure spamd listening on localhost
    [[email protected] ~]# cat /etc/mail/spamassassin/spamc.conf
    -d 127.0.0.1
    /etc/sysconfig/spamassassin
    /etc/default/spamassassin
    Resources:
    https://unix.stackexchange.com/questions/247433/postfix-spamassassin-incoming-mail-headers-changes
    With existing data use this dovecot conf
    https://pastebin.com/ByA7Ev4z
    New installs without existing email data.
    https://pastebin.com/vVrvQnVQ
    For new installations, without any email data, I typically use this version. This uses a universal namespace for the names so it works better with Dovecot 2.3.x and email clients similar to how the cPanel and other ones do out of the box
    Install spamasassin via cyberpanel for new installations without existing email data and files all spam into "INBOX.Junk"
    backup configs:
    and
    Please NOTE:
    Install the required packages
    Ubuntu
    Centos
    copy in the new base one via nano. Replace server.example.com with your hostname and example.com with your domain name.
    ssl_key = <key.pem
    mail_plugins = zlib
    namespace inbox {
    type = private
    separator = .
    prefix = INBOX.
    inbox = yes
    mailbox Drafts {
    special_use = \Drafts
    auto = subscribe
    mailbox Junk {
    special_use = \Junk
    auto = create
    mailbox "Junk Mail" {
    special_use = \Junk
    auto = no
    mailbox "Junk E-mail" {
    special_use = \Junk
    auto = no
    mailbox spam {
    special_use = \Junk
    auto = no
    mailbox Spam {
    special_use = \Junk
    auto = no
    mailbox Trash {
    special_use = \Trash
    auto = subscribe
    mailbox Sent {
    special_use = \Sent
    auto = subscribe
    mailbox "Sent Mail" {
    special_use = \Sent
    auto = no
    mailbox "Sent Messages" {
    special_use = \Sent
    auto = no
    mailbox Archive {
    special_use = \Archive
    auto = create
    mailbox "Archives" {
    auto = no
    service auth {
    mode = 0600
    user = vmail
    mode = 0666
    user = postfix
    group = postfix
    user = root
    user = root
    protocol lda {
    mail_plugins = zlib
    protocol pop3 {
    protocol imap {
    passdb {
    driver = sql
    userdb {
    driver = sql
    plugin {
    zlib_save = gz
    zlib_save_level = 6
    port = 4190
    protocol sieve {
    plugin {
    protocol lda {
    protocol lmtp {
    service stats {
    user = vmail
    group = vmail
    mode = 0660
    user = vmail
    group = vmail
    mode = 0660
    require "fileinto";
    fileinto "INBOX.Junk";
    Start tailing logs:
    To:
    Disable IPv6:
    To make the settings effective, execute :
    sysctl -p
    groupadd spamd
    -d 127.0.0.1
    Resources:
  • I got Sieve up and working on Cyberpanel 2.1.1 Centos 7
    What I noticed was that Cyberpanel's dovecot version was 2.3 but the dovecot-pigeonhole available was not for that version.
    I tried downgrading but that did not work since the configurations of the newer dovecot was different and caused "Authentication Failed" when logging in. So I had to go back up to version 2.3
    These are my steps:
    N.B. Step one will update dovecot to the latest version. Please make sure to keep track of your current version in order to rollback if configuration files clash.
    What you are aiming to do is to get dovecot-pigeonhole the same version as your current setup.
    First setup dovecot repository following this link:
    https://repo.dovecot.org/
    Secondly, follow instructions in this link.
    https://cyberpanel.net/blog/2019/04/18/filtering-spam-in-rainloop-autoreply-and-email-filters-with-sieve/
CyberPanel Discord
Howdy, Stranger!
