Need help regarding DNS TXT record — CyberPanel - WebHosting Control Panel for OpenLiteSpeed
CyberLoader
Hi all,
i have a little issue here when adding a TXT record (for DKIM Public Key).
i have check all the value but when i added it, the name is repeating on the name column...
here is the result:
default._ domainkey.mydomain.com.mydomain.com
supposely -> default._ domainkey.mydomain.com
i am configuring this DNS record from the web and i have tried using different browser but result still the same.
is this a bug or perhaps i did it wrong.
thank you all
Comments
  • edited May 2020
    Are you adding default._domainkey or are you adding default._domainkey.mydomain.com ?
    It should be the first, the domain is always added automatically.
    S-4.host - Sustainable, Secure, Speedy and Stable WP hosting built on Litespeed Ent. and Cyberpanel
  • Thank you very much @S4_Hosting, it solved now....i did it wrong....
  • No problem :-)
CyberPanel Discord
Howdy, Stranger!
