Site down and OpenLiteSpeed does not start — CyberPanel - WebHosting Control Panel for OpenLiteSpeed
CyberLoader
edited July 2020 in Web Server
Hello guys!
Today my site is down so I check in CyperPanel.
In Server Status -> Services Status OpenLiteSpeed is Stopped.
If I click the play icon to start it I got a action complete message but it does not start.
Cyperpanel 2.0 build 1
Ubuntu 18.04.3 (LTS) x64
I am new to these things, I hope you can give me some guidance patiently :)
Thanks
Comments
  • Try going to Server Status > LiteSpeed Status and click the REBOOT LITESPEED button to see if restarting it works. You can also see which processes are running and if you're on the current release of 1.6.14
    If this doesn't resolve the issue, log in to the OpenLiteSped panel at: yourdomain (or IP):7080 and check for issues.
  • Hi @themew
    Thanks for your reply.
    Actualy I am in mydomain:8090 where I have installed Cyberpanel.
    In Server Status > LiteSpeed Status I do not have a Reboot Litespeed button (VERSION: LITESPEED/1.6.13 OPEN)
    I find a restart OpenLiteSpeed button in Server Status -> Services Status but it does not work.
    In error log I have something similar to this:
    https://forums.cyberpanel.net/discussion/4313/openlitespeed-server-broke-after-and-stopped-every-day
  • edited July 2020
    I solved doing these steps:
    sudo apt-get clean
    sudo mv /var/lib/apt/lists /tmp
    sudo mkdir -p /var/lib/apt/lists/partial
    sudo apt-get clean
    sudo apt-get update
    and reboot the droplet.
  • edited July 2020
    Try updating to the latest version of CyberPanel 2.0 build 1 (I use it with Ubuntu as well) and it should fix the issues you're experiencing. Plus the new features will make things easier for you to manage your sites and server.
    Edit: You posted above just as I was saving my reply. Glad to see you got the issue resolved. I would still recommend updating both CyberPanel and OpenLiteSpeed to the latest versions.
  • Ok, is it in a stable version?
  • Yes.
    https://cyberpanel.net/docs/change-log-for-cyberpanel/
CyberPanel Discord
Howdy, Stranger!
In this Discussion
