Redis - Connection Test: Failed on LS plugin — CyberPanel - WebHosting Control Panel for OpenLiteSpeed
CyberLoader
I elected to have Redis installed during the CP install.
"Redis Extension: Enabled" shows green and using port 6379 in the LS plugin.
https://www.dropbox.com/s/psb96192ni0fmd6/redis.png?dl=0
Comments
  • Solution: https://linux4one.com/how-install-redis-on-centos-8/
    *last command (for checking status) should be sudo systemctl status redis.service instead of -server
  • Install Redis daemon
    yum install lsphp71-pecl-redis lsphp72-pecl-redis lsphp73-pecl-redis lsphp74-pecl-redis -y
    yum install redis -y
    systemctl start redis
    systemctl enable redis
    Thanks for sharing such an amazing Blog.
CyberPanel Discord
Howdy, Stranger!
