help me - whmcs cron job is not working — CyberPanel - WebHosting Control Panel for OpenLiteSpeed
CyberLoader
I created the correct cron job but whmcs still doesn't work
[img]https://i.imgur.com/rV2qIdd.png[/img]
[img]https://i.imgur.com/VEwME6t.png[/img]
Comments
  • Hi there,
    Try the following below, where it says lsphp73 change the 73 for the version of php you are using for your WHMCS. Also where it says your domain name put in the domain name for the website.
    /usr/local/lsws/lsphp73/bin/lsphp -q /home/your domain name/public_html/billing/crons/cron.php >/dev/null 2>&1
    Thanks
    Bossmanuk
  • Type your comment> @Bossmanuk said:
    > Hi there,
    > Thanks
    > Bossmanuk
    [img]https://i.imgur.com/o3Husc1.png[/img] still doesn't work
  • has been successful thank you
CyberPanel Discord
Howdy, Stranger!
