Hi, I am new to Cyberpanel. I need urgent help to correctly configure the Cronjob, it is a system that issues invoices but when migrating it to Cyberpanel the recurring invoicing is not working well, I think it is the URL that I have entered wrong, can you tell me if it is correct?
0 11 * * * /usr/local/bin/php /home/mydomain.com/invoice-ninja/artisan ninja:send-invoices
I have also tried
0 11 * * * /usr/local/lsws/lsphp72/bin/php home/mydomain.com/invoice-ninja/artisan ninja:send-invoices
But neither one works for me
I really appreciate the support
Comments
if your website uses the PHP version 7.2 then
the cron will be like
0 11 * * * /usr/local/lsws/lsphp72/bin/php /home/mydomain.com/invoice-ninja/artisan ninja:send-invoices
also try to manually execute the command and output works fine
In SSH when I enter the command: CyberPanel ninja:send-invoices
I have it in a subdomain, is that the problem?
