Phyton process takes 100cpu starts morning and wont shut down. — CyberPanel - WebHosting Control Panel for OpenLiteSpeed
CyberLoader
Any idea how fix this?
I have to kill manually everyday process below:
root 41436 99.2 1.6 160932 65200 ? R 00:00 375:44 /usr/local/CyberCP/bin/python /usr/local/CyberC
[09.05.2021_07-05-22] Trying to obtain SSL for: panel.dreamcatchers-events.com
[09.05.2021_07-05-31] Failed to obtain SSL, issuing self-signed SSL for: panel.dreamcatchers-events.com
[09.05.2021_07-05-31] Websites matching query does not exist. [installSSLForDomain:72]
[09.05.2021_07-05-31] Self signed SSL issued for panel.dreamcatchers-events.com.
[09.05.2021_07-39-06] 'tempPath' [backupStatus]
[09.05.2021_07-39-11] 'backupDestinations'
[09.05.2021_07-45-10] 'tempPath' [backupStatus]
[09.05.2021_07-45-32] 'tempPath' [backupStatus]
[09.05.2021_14-08-24] 'tempPath' [backupStatus]
[09.05.2021_14-11-44] 'tempPath' [backupStatus]
[09.05.2021_15-02-36] 'tempPath' [backupStatus]
mysqldump: Got error: 1045: "Access denied for user 'root'@'localhost' (using password: YES)" when trying to connect
[09.06.2021_00-00-08] Database: QhQoquyvh8WVSKcould not be backed! [createDatabaseBackup]
[09.06.2021_02-00-02] Running SSL Renew Utility
[09.06.2021_02-00-02] Checking SSL for spiceislandhome.com.
[09.06.2021_02-00-02] SSL exists for spiceislandhome.com. Checking if SSL will expire in 15 days..
[09.06.2021_02-00-02] SSL exists for spiceislandhome.com and is not ready to renew, skipping..
[09.06.2021_02-00-02] Checking SSL for dreamcatchers-events.com.
[09.06.2021_02-00-02] SSL exists for dreamcatchers-events.com. Checking if SSL will expire in 15 days..
[09.06.2021_02-00-02] SSL exists for dreamcatchers-events.com and is not ready to renew, skipping..
[09.06.2021_02-00-02] Checking SSL for mail.spiceislandhome.com.
[09.06.2021_02-00-02] SSL exists for mail.spiceislandhome.com. Checking if SSL will expire in 15 days..
[09.06.2021_02-00-02] SSL exists for mail.spiceislandhome.com and is not ready to renew, skipping..
[09.06.2021_02-00-02] Checking SSL for mail.dreamcatchers-events.com.
[09.06.2021_02-00-02] SSL exists for mail.dreamcatchers-events.com. Checking if SSL will expire in 15 days..
[09.06.2021_02-00-02] SSL exists for mail.dreamcatchers-events.com and is not ready to renew, skipping..
[09.06.2021_02-00-02] Checking SSL for panel.dreamcatchers-events.com.
[09.06.2021_02-00-02] SSL exists for panel.dreamcatchers-events.com. Checking if SSL will expire in 15 days..
[09.06.2021_02-00-02] SSL exists for panel.dreamcatchers-events.com and is not ready to renew, skipping..
[09.06.2021_22-11-29] Expecting value: line 1 column 1 (char 0)
[09.06.2021_22-11-43] Expecting value: line 1 column 1 (char 0)
[09.07.2021_00-00-09] Database: QhQoquyvh8WVSKcould not be backed! [createDatabaseBackup]
[09.07.2021_02-00-02] Running SSL Renew Utility
[09.07.2021_02-00-02] Checking SSL for spiceislandhome.com.
[09.07.2021_02-00-02] SSL exists for spiceislandhome.com. Checking if SSL will expire in 15 days..
[09.07.2021_02-00-02] SSL exists for spiceislandhome.com and is not ready to renew, skipping..
[09.07.2021_02-00-02] Checking SSL for dreamcatchers-events.com.
[09.07.2021_02-00-02] SSL exists for dreamcatchers-events.com. Checking if SSL will expire in 15 days..
[09.07.2021_02-00-02] SSL exists for dreamcatchers-events.com and is not ready to renew, skipping..
[09.07.2021_02-00-02] Checking SSL for mail.spiceislandhome.com.
[09.07.2021_02-00-02] SSL exists for mail.spiceislandhome.com. Checking if SSL will expire in 15 days..
[09.07.2021_02-00-02] SSL exists for mail.spiceislandhome.com and is not ready to renew, skipping..
[09.07.2021_02-00-02] Checking SSL for mail.dreamcatchers-events.com.
[09.07.2021_02-00-02] SSL exists for mail.dreamcatchers-events.com. Checking if SSL will expire in 15 days..
[09.07.2021_02-00-02] SSL exists for mail.dreamcatchers-events.com and is not ready to renew, skipping..
[09.07.2021_02-00-02] Checking SSL for panel.dreamcatchers-events.com.
[09.07.2021_02-00-02] SSL exists for panel.dreamcatchers-events.com. Checking if SSL will expire in 15 days..
[09.07.2021_02-00-02] SSL exists for panel.dreamcatchers-events.com and is not ready to renew, skipping..
Comments
  • I found its incremental backup cron, Its doing daily backup to local storage. I have other cron for weekly backup, to S3 but not tested that yet. Any idea how fix that?
    0 0 * * * /usr/local/CyberCP/bin/python /usr/local/CyberCP/IncBackups/IncScheduler.py Daily
  • I fixed problem by making new server manually. previous server was one click installation package from digitalocean.
  • Facing the same issue. Whether you have solved it
CyberPanel Discord
Howdy, Stranger!
