Problem with port 443 only in few domains, other dont why ? — CyberPanel - WebHosting Control Panel for OpenLiteSpeed
I upgraded to latest version, i have a problem with SSL , or 443 port ? i dont know where some domains does not work in ssl
the server has a few domains and works fine without ssl , but does not work with SSL on some domains
If i browse http://mydomain.com it works fine, but it does not work in https (the ssl with letsencript is perfectly generated) i have 10 domains with ssl generated, but only 5 the connection to ssl gives ERR_CONNECTION_REFUSED
ITs not a port or general server problem, because some domains in the same server works fine with ssl
i checked all .conf and logs files and i dont know where to fix it.
i repeat its not problem generating ssl, because i generated in cli and give no error.
What im missing ? Thanks for your help.
Comments
Howdy, Stranger!
This Site is currently in maintenance mode.
Please check back here later.
→ Site Settings
