help — CyberPanel - WebHosting Control Panel for OpenLiteSpeed
CyberLoader
help
Retrying (Retry(total=4, connect=None, read=None, redirect=None)) after connection broken by 'ReadTimeoutError("HTTPSConnectionPool(host='pypi.org', port=443): Read timed out. (read timeout=15)",)': /simple/django/
pls help :(
Comments
  • Collecting django==1.11
    Retrying (Retry(total=3, connect=None, read=None, redirect=None)) after connection broken by 'ReadTimeoutError("HTTPSConnectionPool(host='pypi.org', port=443): Read timed out. (read timeout=15)",)': /simple/django/
    Retrying (Retry(total=2, connect=None, read=None, redirect=None)) after connection broken by 'ReadTimeoutError("HTTPSConnectionPool(host='pypi.org', port=443): Read timed out. (read timeout=15)",)': /simple/django/
    Retrying (Retry(total=1, connect=None, read=None, redirect=None)) after connection broken by 'ReadTimeoutError("HTTPSConnectionPool(host='pypi.org', port=443): Read timed out. (read timeout=15)",)': /simple/django/
    Retrying (Retry(total=0, connect=None, read=None, redirect=None)) after connection broken by 'ReadTimeoutError("HTTPSConnectionPool(host='pypi.org', port=443): Read timed out. (read timeout=15)",)': /simple/django/
    Could not find a version that satisfies the requirement django==1.11 (from versions: )
    No matching distribution found for django==1.11
  • Package python-setuptools-0.9.8-7.el7.noarch already installed and latest version
    Nothing to do
    [09-31-48-Mon-Dec-2018] Python setup tools Successfully installed!
    Retrying (Retry(total=4, connect=None, read=None, redirect=None)) after connection broken by 'ReadTimeoutError("HTTPSConnectionPool(host='pypi.python.org', port=443): Read timed out. (read timeout=15)",)': /simple/django/
    File "install.py", line 3647, in
    main()
    Operation cancelled by user
    again problem :(
  • edited December 2018
    django fail
CyberPanel Discord
Howdy, Stranger!
